Ga door naar hoofdinhoud
Nvidia Shield Pro Android TV Bottom Cover Replacement
Wat je nodig hebt
  1. Nvidia Shield Pro Android TV Bottom Cover Replacement, Bottom Cover: stap 1, afbeelding 1 van 2 Nvidia Shield Pro Android TV Bottom Cover Replacement, Bottom Cover: stap 1, afbeelding 2 van 2
    • Flip to the back side of your Nvidia Shield Pro Android TV.
    • To open the bottom cover of the Nvidia Shield, start from the corner and slide your plastic opening tool across the gap.
    • If using a plastic opening tool to open the bottom cover is difficult, try using a metal spudger.
Conclusie
Christian De Vera
167 Reputatie
1 Handleiding geschreven
Cal Poly, Team S18-G2, White Winter 2020 Lid van Cal Poly, Team S18-G2, White Winter 2020
CPSU-WHITE-W20S18G2
4 Leden
14 handleidingen geschreven
1Gids Commentaar
Hi, Shield Pro 2.
Remove 2 small cross head screws securing top cover to the back plate. Next you have to pry open the back edge and then slide the top cover forwards about 8mm away from the back plate to clear 3 catch points along each side.
S. Carter - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 81
Altijd: 2,920
