Ga door naar hoofdinhoud
NVIDIA SHIELD Portable Motherboard Replacement
Wat je nodig hebt
  1. NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: stap 1, afbeelding 1 van 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: stap 1, afbeelding 2 van 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Front Panel: stap 1, afbeelding 3 van 3
    • Remove the seven 6.4mm T5 Torx screws from the back panel.
    • Use the spudger to separate the front and back panels.
  2. NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: stap 2, afbeelding 1 van 2 NVIDIA SHIELD Portable Motherboard Replacement, Remove Green Grill: stap 2, afbeelding 2 van 2
    • The green grill is not screwed in so it can be pulled right out.
  3. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: stap 3, afbeelding 1 van 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: stap 3, afbeelding 2 van 3 NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Cables: stap 3, afbeelding 3 van 3
    • Remove the six 6.5mm T5 Torx screws.
    • Disconnect the power wires.
    • Peel back the copper tape and disconnect the black and white wires.
  4. NVIDIA SHIELD Portable Motherboard Replacement, Remove Battery Apparatus: stap 4, afbeelding 1 van 1
    • Pull the battery apparatus out once all cables are removed.
  5. NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: stap 5, afbeelding 1 van 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: stap 5, afbeelding 2 van 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Fan: stap 5, afbeelding 3 van 3
    • Cooling is important for electronics, the last thing they want is to overheat.
    • Remove the two 7.3mm and four 8.4mm T5 Torx screws and disconnect the power cable.
    • Lift the fan free after the screws and cable are removed.
  6. NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: stap 6, afbeelding 1 van 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: stap 6, afbeelding 2 van 3 NVIDIA SHIELD Portable Motherboard Replacement, Removing Logic Board: stap 6, afbeelding 3 van 3
    • The large board under the back case is the motherboard.
    • Using your T5 Torx screwdriver, remove six screws from the motherboard—two 7.3 mm screws and four 8.4 mm screws.
    • Simply pull gently on the edges of the board, wiggling it if necessary so as not to damage the ports at the top of the board.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Marc Perez
545 Reputatie
2 handleidingen geschreven
USF Tampa, Team 1-1, Hickman Fall 2014 Lid van USF Tampa, Team 1-1, Hickman Fall 2014
USFT-HICKMAN-F14S1G1
4 Leden
18 handleidingen geschreven
Één opmerking
Hay ich suche Ersatzteile für Nvidia shield Portable ich suche Board da wo kühler drauf ist , weil mein ist kaput gegangen :(
Konstantin Styngu - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 1,799
