Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Nvidia Shield Controller te repareren, gebruik onze reparatiehandleidingen.
  1. Nvidia Shield Controller Teardown, Nvidia Shield Controller Teardown: stap 1, afbeelding 1 van 2 Nvidia Shield Controller Teardown, Nvidia Shield Controller Teardown: stap 1, afbeelding 2 van 2
    • Nvidia Shield Normal Controller, without Display, so it's just a controller if you don't have other shield device
    • Micro-USB 2.0
    • 3.5 mm stereo headphone jack
    • Charge indicator
    • Still don't know how this controller connected to PC without cables, the controller can be connected to a Nvidia Shield through WiFi but no idea if this works with pc.
  2. Nvidia Shield Controller Teardown: stap 2, afbeelding 1 van 3 Nvidia Shield Controller Teardown: stap 2, afbeelding 2 van 3 Nvidia Shield Controller Teardown: stap 2, afbeelding 3 van 3
    • Flipping over the device reveals 6 screws. No hidden screws here.
    • 6*screws, use T7 screwdriver for all of screws。
    • Careful, you will need some force to open the clips holding the device together.
    • Once you are inside the device remove the two ribbon cables.
  3. Nvidia Shield Controller Teardown, Vibration Motors: stap 3, afbeelding 1 van 2 Nvidia Shield Controller Teardown, Vibration Motors: stap 3, afbeelding 2 van 2
    • Remove two cable for the vibration motors and one cable for the battery.
    • There are 2 Vibration motors
    • Remove the two screws holding the logic board to the device.
    • Carefully remove the logic board.
  4. Nvidia Shield Controller Teardown, Battery: stap 5, afbeelding 1 van 2 Nvidia Shield Controller Teardown, Battery: stap 5, afbeelding 2 van 2
    • we can found battery part under the motherboard
    • Screw*4
    • LC18650 Lithium-ion Battery: 3.6V/2200mAh/7.92Wh
  5. Nvidia Shield Controller Teardown, Motherboard: stap 6, afbeelding 1 van 2 Nvidia Shield Controller Teardown, Motherboard: stap 6, afbeelding 2 van 2
    • Main PCB - Front:
    • TLV320AIC3204 (Very Low-Power Stereo Audio CODEC)
    • Atmel ATXMEGA32A4U-AU (8-bit Microcontroller)
    • Potentiometers
    • Main PCB - Back:
    • Microchip SST25WF020A (SPI Flash 2Mbit 1.8V)
    • Ozmo2000 431-B0 (WiFi Integrated Chip)
    • ADG3 3088CP (Unknown)
  6. Nvidia Shield Controller Teardown, LT&RT: stap 7, afbeelding 1 van 3 Nvidia Shield Controller Teardown, LT&RT: stap 7, afbeelding 2 van 3 Nvidia Shield Controller Teardown, LT&RT: stap 7, afbeelding 3 van 3
    • Remove 6*screw
    • careful,don't broke the potentiometer
  7. Nvidia Shield Controller Teardown: stap 8, afbeelding 1 van 3 Nvidia Shield Controller Teardown: stap 8, afbeelding 2 van 3 Nvidia Shield Controller Teardown: stap 8, afbeelding 3 van 3
    • cover part
    • 4*screw
    • PIC32MX120F032D-I/PT (32-bit Microcontroller)
    • PIC18F26K22-I/ML (8-bit Microcontroller)
13314877
90 Reputatie
1 Handleiding geschreven
18 opmerkingen
Where is the Shield console teardown?
Steve Hanson - Antwoord
I brought the controller to the hardware store and found that a T6 fit perfect. I bought it and used it, worked fine. I know the description says T7. May be a mistake
Farrid Mailloux - Antwoord
Farrid is Correct I have both a T7 and T6 Screwdriver and the T7 IS TOO BIG!, T6 fits perfectly. Just a heads up to anyone who needs to go out and but a Single screwdriver.
drestine -
You are right. It’s T6, not T7.
nguyen bui thanh -
Looking to replace ribbon cables. Anyone know where i can buy them?
Dave Miller - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 44
Altijd: 11,810
