Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
Be aware that most of your time will be spent getting the back off of the device. However, once in the device the repair is quick and easy.
  1. Use a Heat Gun to loosen the adhesive around the inside of the device. Use prying tools to lift the back of the device up.
    • Use a Heat Gun to loosen the adhesive around the inside of the device.
    • Use prying tools to lift the back of the device up.
    • I recommend prying up one side at a time and heating the adhesive to 'just barely too hot to touch'.
  2. Unscrew the headphone jack from the device.
    • Unscrew the headphone jack from the device.
  3. Unlock the headphone jack ribbon.
    • Unlock the headphone jack ribbon.
  4. Move the wires out of the way and slowly pull the ribbon out of the circuit dock.
    • Move the wires out of the way and slowly pull the ribbon out of the circuit dock.
  5. Lift headphone jack/ribbon out and it's FREE!
    • Lift headphone jack/ribbon out and it's FREE!
Conclusie
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 194
