Ga door naar hoofdinhoud
Nutri Ninja Ninja Blender Duo BL641 Blade Replacement
Wat je nodig hebt
  1. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement, Blade: stap 1, afbeelding 1 van 2 Nutri Ninja Ninja Blender Duo BL641 Blade Replacement, Blade: stap 1, afbeelding 2 van 2
    • Make sure blender is turned off.
    • Lift open the lid of blender by pressing the "Release" button and move to the side
  2. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: stap 2, afbeelding 1 van 2 Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: stap 2, afbeelding 2 van 2
    • Carefully Grab the top of the blade and pull upward with medium force.
    • The blade should slide out easily.
    • Do not touch the blades! Even when dull they can still cut you.
  3. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: stap 3, afbeelding 1 van 2 Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: stap 3, afbeelding 2 van 2
    • Carefully pick up the new blade and match the bottom star shaped opening to the star shaped protrusion from the blender.
  4. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: stap 4, afbeelding 1 van 1
    • Slowly connect the two star shapes together and push down until it reaches the bottom.
Conclusie
Now your blender can resume blending to perfection.
Charlotte
101 Reputatie
1 Handleiding geschreven
Cal Poly, Team S7-G1, Banghart Fall 2017 Lid van Cal Poly, Team S7-G1, Banghart Fall 2017
CPSU-BANGHART-F17S7G1
5 Leden
6 handleidingen geschreven
1Gids Commentaar
A funny little guide
glicerico - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 17
Altijd: 3,470
