Ga door naar hoofdinhoud
Numark TT1600 Tone Arm Replacement
Wat je nodig hebt
  1. Numark TT1600 Tone Arm Replacement, Tone Arm: stap 1, afbeelding 1 van 2 Numark TT1600 Tone Arm Replacement, Tone Arm: stap 1, afbeelding 2 van 2
    • Flip over the turntable and remove the 9 screws on the outer edges.
  2. Numark TT1600 Tone Arm Replacement: stap 2, afbeelding 1 van 1
    • Remove the back cover by pulling it apart.
  3. Numark TT1600 Tone Arm Replacement: stap 3, afbeelding 1 van 3 Numark TT1600 Tone Arm Replacement: stap 3, afbeelding 2 van 3 Numark TT1600 Tone Arm Replacement: stap 3, afbeelding 3 van 3
    • Remove the clip located on the backside of the audio jack housing by gently pulling it out.
    • There will be some resistance but continue to pull gently.
    • The clip is located right underneath the audio jacks.
  4. Numark TT1600 Tone Arm Replacement: stap 4, afbeelding 1 van 3 Numark TT1600 Tone Arm Replacement: stap 4, afbeelding 2 van 3 Numark TT1600 Tone Arm Replacement: stap 4, afbeelding 3 van 3
    • Remove the screw that connects the black wire of the tone arm to the base of the audio jack housing.
  5. Numark TT1600 Tone Arm Replacement: stap 5, afbeelding 1 van 2 Numark TT1600 Tone Arm Replacement: stap 5, afbeelding 2 van 2
    • Gently pull the wire that you just unscrewed to release it from the clip.
  6. Numark TT1600 Tone Arm Replacement: stap 6, afbeelding 1 van 3 Numark TT1600 Tone Arm Replacement: stap 6, afbeelding 2 van 3 Numark TT1600 Tone Arm Replacement: stap 6, afbeelding 3 van 3
    • Remove the two screws connecting the circuit board to the tone arm.
  7. Numark TT1600 Tone Arm Replacement: stap 7, afbeelding 1 van 2 Numark TT1600 Tone Arm Replacement: stap 7, afbeelding 2 van 2
    • Remove the two remaining screws connecting the tone arm to the device.
  8. Numark TT1600 Tone Arm Replacement: stap 8, afbeelding 1 van 1
    • Flip the turntable back over to the top side.
    • Remove the counter weight located at the back of the tone arm.
  9. Numark TT1600 Tone Arm Replacement: stap 9, afbeelding 1 van 3 Numark TT1600 Tone Arm Replacement: stap 9, afbeelding 2 van 3 Numark TT1600 Tone Arm Replacement: stap 9, afbeelding 3 van 3
    • Push out the pin keeping the tone arm in place using a Phillips #00 screwdriver.
    • Once you have pushed the pin out with the screwdriver, pull the rest of it out using your hand.
  10. Numark TT1600 Tone Arm Replacement: stap 10, afbeelding 1 van 3 Numark TT1600 Tone Arm Replacement: stap 10, afbeelding 2 van 3 Numark TT1600 Tone Arm Replacement: stap 10, afbeelding 3 van 3
    • Pick up the tone arm and point the back end of it towards its base.
    • Push the back end of the tone arm into the hole.
    • Flip the turntable over and pull the tone arm all the way through the hole.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Nikolai
254 Reputatie
5 handleidingen geschreven
Cal Poly, Team 17-14, Regan Fall 2011 Lid van Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 41
Altijd: 8,290
