Ga door naar hoofdinhoud
Numark TT1600 Belt Drive Replacement
  1. Numark TT1600 Belt Drive Replacement, Belt Drive: stap 1, afbeelding 1 van 1
    • Remove slip mat from top of the platter.
  2. Numark TT1600 Belt Drive Replacement: stap 2, afbeelding 1 van 1
    • Remove platter by inserting thumbs in holes and slowly pulling up.
    • There will be some initial resistance.
  3. Numark TT1600 Belt Drive Replacement: stap 3, afbeelding 1 van 1
    • Remove damaged belt which will be located below the platter.
  4. Numark TT1600 Belt Drive Replacement: stap 4, afbeelding 1 van 1
    • Install new belt by securing it around the inner ring, located on the back of the platter.
  5. Numark TT1600 Belt Drive Replacement: stap 5, afbeelding 1 van 1
    • Place a thumb in each hole.
    • You should be able to feel the rubber belt.
    • Gently pull the belt with each thumb, keeping the belt taut around the inner ring.
  6. Numark TT1600 Belt Drive Replacement: stap 6, afbeelding 1 van 2 Numark TT1600 Belt Drive Replacement: stap 6, afbeelding 2 van 2
    • Secure platter back on turntable while keeping belt taut.
    • Pull belt around motor spindle.
    • Gently let go of belt.
  7. Numark TT1600 Belt Drive Replacement: stap 7, afbeelding 1 van 1
    • Test turntable by spinning the platter.
    • There should be slight tension causing the platter to come to a stop.
Eindstreep
Nikolai
254 Reputatie
5 handleidingen geschreven
Cal Poly, Team 17-14, Regan Fall 2011 Lid van Cal Poly, Team 17-14, Regan Fall 2011
CPSU-REGAN-F11S17G14
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 45
Altijd: 6,292
