Inleiding
Follow these steps to remove the MicroSD from your NuVision DUO 11 as well as replacement.
Wat je nodig hebt
Place the flat end of a nylon spudger in the gap between the cover and the rest of the device.
Slide the spudger down each side until you hear numerous clicks.
Remove the back panel from the tablet.
Remove the 4.8 mm screws from the MicroSD port using a JIS #000 screwdriver.
Unclip the male ribbon from the female ribbon port carefully.
Remove the MicroSD port from the tablet.
