Ga door naar hoofdinhoud
NuVision 10.1 Atom Motherboard Replacement
Wat je nodig hebt
  1. NuVision 10.1 Atom Motherboard Replacement, Camera: stap 1, afbeelding 1 van 3 NuVision 10.1 Atom Motherboard Replacement, Camera: stap 1, afbeelding 2 van 3 NuVision 10.1 Atom Motherboard Replacement, Camera: stap 1, afbeelding 3 van 3
    • Turn the device screen side down.
    • Carefully remove the back piece with the iFixit opening tool.
  2. NuVision 10.1 Atom Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the yellow tape covering the motherboard gently with your fingers.
  3. NuVision 10.1 Atom Motherboard Replacement: stap 3, afbeelding 1 van 3 NuVision 10.1 Atom Motherboard Replacement: stap 3, afbeelding 2 van 3 NuVision 10.1 Atom Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Pull the camera plug upward and away from the motherboard with your fingers.
    • Gently pull the camera from the device. The camera is held by tension.
  4. NuVision 10.1 Atom Motherboard Replacement, Speaker: stap 4, afbeelding 1 van 1
    • Carefully remove silver tape with your fingers.
  5. NuVision 10.1 Atom Motherboard Replacement: stap 5, afbeelding 1 van 2 NuVision 10.1 Atom Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Remove speakers gently using your fingers, they pop out easily.
    • Disconnect cords attached to the speaker from white pod.
  6. NuVision 10.1 Atom Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 1
    • Disconnect the press-fit black and red curly wire from where it connects on the motherboard.
  7. NuVision 10.1 Atom Motherboard Replacement: stap 7, afbeelding 1 van 3 NuVision 10.1 Atom Motherboard Replacement: stap 7, afbeelding 2 van 3 NuVision 10.1 Atom Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Gently remove the battery's three ZIF connectors from the motherboard. Use your fingers.
    • Be careful not to puncture the battery.
  8. NuVision 10.1 Atom Motherboard Replacement: stap 8, afbeelding 1 van 2 NuVision 10.1 Atom Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Disconnect the battery's bundled cable connector from the motherboard with fingers.
  9. NuVision 10.1 Atom Motherboard Replacement: stap 9, afbeelding 1 van 3 NuVision 10.1 Atom Motherboard Replacement: stap 9, afbeelding 2 van 3 NuVision 10.1 Atom Motherboard Replacement: stap 9, afbeelding 3 van 3
    • Remove the four black 3.32mm screws on the corners of the motherboard using the Phillips #000 screwdriver. The motherboard should come out easily.
Conclusie
Laila Schulz
219 Reputatie
1 Handleiding geschreven
USF Tampa, Team S1-G5, Leahy Spring 2019 Lid van USF Tampa, Team S1-G5, Leahy Spring 2019
USFT-LEAHY-S19S1G5
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 443
