Ga door naar hoofdinhoud
Novatel MiFi 2 4G LTE Hotspot SIM Card Replacement
  1. Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, Battery Cover: stap 1, afbeelding 1 van 3 Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, Battery Cover: stap 1, afbeelding 2 van 3 Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, Battery Cover: stap 1, afbeelding 3 van 3
    • Unplug the charger from your Novatel Hotspot device.
    • Place the Novatel Hotspot device face down on a flat, clean surface.
    • Place your thumb under the latch of the black plastic battery cover as shown.
    • Remove the battery cover. This will require some force.
  2. Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, Battery: stap 2, afbeelding 1 van 2 Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, Battery: stap 2, afbeelding 2 van 2
    • Gently place your thumb on the right side of the battery as shown.
    • Remove the battery from its socket by lifting it up and out.
  3. Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, SIM Card: stap 3, afbeelding 1 van 3 Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, SIM Card: stap 3, afbeelding 2 van 3 Novatel MiFi 2 4G LTE Hotspot  SIM Card  Replacement, SIM Card: stap 3, afbeelding 3 van 3
    • Once the battery has been removed, the SIM Card slot can be accessed.
    • Carefully take out the dead SIM Card by lifting it from its position with your fingers.
Conclusie
GerardFoley
351 Reputatie
4 handleidingen geschreven
Marist, Team S1-G5, Chaterdon Fall 2018 Lid van Marist, Team S1-G5, Chaterdon Fall 2018
MARS-CHATERDON-F18S1G5
3 Leden
Één opmerking
What kind of SIM card do I need for this?
Abner - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 726
