Ga door naar hoofdinhoud
Nostalgia Electrics RHP-310 Wiring Repair
Wat je nodig hebt
  1. Nostalgia Electrics RHP-310 Wiring Repair, Power Switch: stap 1, afbeelding 1 van 1
    • Unplug the popper.
    • Lift the lid up to remove it.
  2. Nostalgia Electrics RHP-310 Wiring Repair: stap 2, afbeelding 1 van 1
    • Lay the popper on its side.
    • Remove the five 12mm Philips #2 screws around the perimeter of the base with the Phillips #2 screwdriver.
    • Remove the two 15mm Philips #2 screws in the center of the base with the Phillips #2 screwdriver.
    • Put the removed screws in a safe place, they will be needed later to reattach the housing to the base.
  3. Nostalgia Electrics RHP-310 Wiring Repair: stap 3, afbeelding 1 van 1
    • Flip the base over to view the interior of the base panel.
    • Unscrew the two 10 mm Philips #2 screws from the base panel.
    • Remove the base and set it aside.
  4. Nostalgia Electrics RHP-310 Wiring Repair: stap 4, afbeelding 1 van 2 Nostalgia Electrics RHP-310 Wiring Repair: stap 4, afbeelding 2 van 2
    • Locate the power switch connected to the side of the housing.
    • Pinch the sides of the power switch.
    • Push the power button up and out of the housing.
  5. Nostalgia Electrics RHP-310 Wiring Repair: stap 5, afbeelding 1 van 1
    • Remove the wires connected to the power switch that should be detached from the housing.
    • Gently pry the wires loose from the power switch with the plastic opening tool.
    • The wires should easily pop out from the power switch.
  6. Nostalgia Electrics RHP-310 Wiring Repair: stap 6, afbeelding 1 van 1
    • Remove the power switch from the housing unit.
    • You can now replace the power switch, if necessary.
  7. Nostalgia Electrics RHP-310 Wiring Repair, Replacing Housing: stap 7, afbeelding 1 van 2 Nostalgia Electrics RHP-310 Wiring Repair, Replacing Housing: stap 7, afbeelding 2 van 2
    • Gently remove the heating component from the popper.
    • Unscrew the four screws (11mm Philips #2 screws) that connect the white top to the housing.
    • Save the screws from this step. You will need them to connect the new housing to the white top.
  8. Nostalgia Electrics RHP-310 Wiring Repair: stap 8, afbeelding 1 van 1
    • Remove the white top from the housing.
  9. Nostalgia Electrics RHP-310 Wiring Repair, Replacing Fan: stap 9, afbeelding 1 van 1
    • Unscrew the three 10 mm Philips #2 screws that hold the heating component together.
    • Keep the screws in a safe place. You will need them to put the heating component back together.
  10. Nostalgia Electrics RHP-310 Wiring Repair: stap 10, afbeelding 1 van 1
    • Pull the heating component apart.
  11. Nostalgia Electrics RHP-310 Wiring Repair: stap 11, afbeelding 1 van 2 Nostalgia Electrics RHP-310 Wiring Repair: stap 11, afbeelding 2 van 2
    • Locate the fan.
    • Pull the fan off the motor.
    • Do not pull too hard or you will break the motor.
  12. Nostalgia Electrics RHP-310 Wiring Repair: stap 12, afbeelding 1 van 1
    • You can now replace the fan. If there is debris, clean it out.
  13. Nostalgia Electrics RHP-310 Wiring Repair, Nostalgia Electrics RHP-310 Wiring Repair: stap 13, afbeelding 1 van 1
    • Take the heating coil out of complete heating component.
  14. Nostalgia Electrics RHP-310 Wiring Repair: stap 14, afbeelding 1 van 1
    • Visually check the wires for frayed wires.
    • Make sure that the wires are completely connected to a port.
  15. Nostalgia Electrics RHP-310 Wiring Repair: stap 15, afbeelding 1 van 1
    • If you see a wire that is not connected, solder it back into place.
    • These websites might be helpful in soldering: Wikipedia Theoatc
    • Also, use a digital multi-meter to check to make sure there is a current through the wire. If the meter does not read, you might need to replace all the wires.
    • This website may be helpful in with wiring: How Stuff Works
  16. Nostalgia Electrics RHP-310 Wiring Repair: stap 16, afbeelding 1 van 1
    • This website will help with reconnecting wires:eHow
Conclusie
Dana Clarke
50 Reputatie
6 handleidingen geschreven
Cal Poly, Team 16-57, Forte Fall 2012 Lid van Cal Poly, Team 16-57, Forte Fall 2012
CPSU-FORTE-F12S16G57
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 10
Altijd: 890
