Inleiding
This guide will outline how to replace the fan inside the heating component.
Wat je nodig hebt
Gently remove the heating component from the popper.
Unscrew the four screws (11mm Philips #2 screws) that connect the white top to the housing.
Unscrew the three 10 mm Philips #2 screws that hold the heating component together.
You can now replace the fan. If there is debris, clean it out.
The fan sounded funny, so I have taken my popcorn popper apart, and removed the fan. The center hole in the plastic fan where it attaches to the motor shaft is cracked and the fan needs to be replaced. Do you have any idea where I can get a new one? This seems to be a special part made of a high heat resistant plastic.
Één andere persoon heeft deze handleiding voltooid.
