Ga door naar hoofdinhoud
Nortel Networks i2004 IP Speaker Replacement
Wat je nodig hebt
  1. Nortel Networks i2004 IP Speaker Replacement, Back Cover: stap 1, afbeelding 1 van 3 Nortel Networks i2004 IP Speaker Replacement, Back Cover: stap 1, afbeelding 2 van 3 Nortel Networks i2004 IP Speaker Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Flip the phone over to view the back.
    • Remove the power and phone cords.
  2. Nortel Networks i2004 IP Speaker Replacement: stap 2, afbeelding 1 van 1
    • Remove the seven 8mm Phillips #2 screws.
  3. Nortel Networks i2004 IP Speaker Replacement: stap 3, afbeelding 1 van 2 Nortel Networks i2004 IP Speaker Replacement: stap 3, afbeelding 2 van 2
    • Lift up the back cover slowly because there are still wires attached to the circuit board.
    • Lifting the back cover should not require a lot of force; simply lift with your fingertips.
  4. Nortel Networks i2004 IP Speaker Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
  5. Nortel Networks i2004 IP Speaker Replacement: stap 5, afbeelding 1 van 2 Nortel Networks i2004 IP Speaker Replacement: stap 5, afbeelding 2 van 2
    • Remove the six 8mm Phillips #2 screws.
    • Pull the speaker phone cover straight up.
  6. Nortel Networks i2004 IP Speaker Replacement, Speaker: stap 6, afbeelding 1 van 1
    • Lift the speaker straight up.
    • The speaker may need to be slightly wiggled in order to loosen and remove.
  7. Nortel Networks i2004 IP Speaker Replacement: stap 7, afbeelding 1 van 1
    • Cut the red and white wires as close to the speaker as possible.
    • Wire cutters are preferred, but normal scissors are fine too.
  8. Nortel Networks i2004 IP Speaker Replacement: stap 8, afbeelding 1 van 2 Nortel Networks i2004 IP Speaker Replacement: stap 8, afbeelding 2 van 2
    • Solder wires to new speaker.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Elizabeth
160 Reputatie
3 handleidingen geschreven
Cal Poly, Team 10-35, Amido Winter 2012 Lid van Cal Poly, Team 10-35, Amido Winter 2012
CPSU-AMIDO-W12S10G35
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 9
Altijd: 1,131
