Ga door naar hoofdinhoud
Nortel Networks i2004 IP Buttons Replacement
Wat je nodig hebt
  1. Nortel Networks i2004 IP Buttons Replacement, Back Cover: stap 1, afbeelding 1 van 3 Nortel Networks i2004 IP Buttons Replacement, Back Cover: stap 1, afbeelding 2 van 3 Nortel Networks i2004 IP Buttons Replacement, Back Cover: stap 1, afbeelding 3 van 3
    • Flip the phone over to view the back.
    • Remove the power and phone cords.
  2. Nortel Networks i2004 IP Buttons Replacement: stap 2, afbeelding 1 van 1
    • Remove the seven 8mm Phillips #2 screws.
  3. Nortel Networks i2004 IP Buttons Replacement: stap 3, afbeelding 1 van 2 Nortel Networks i2004 IP Buttons Replacement: stap 3, afbeelding 2 van 2
    • Lift up the back cover slowly because there are still wires attached to the circuit board.
    • Lifting the back cover should not require a lot of force; simply lift with your fingertips.
  4. Nortel Networks i2004 IP Buttons Replacement: stap 4, afbeelding 1 van 1
    • Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
  5. Nortel Networks i2004 IP Buttons Replacement: stap 5, afbeelding 1 van 2 Nortel Networks i2004 IP Buttons Replacement: stap 5, afbeelding 2 van 2
    • Remove the six 8mm Phillips #2 screws.
    • Pull the speaker phone cover straight up.
  6. Nortel Networks i2004 IP Buttons Replacement, Circuit Board: stap 6, afbeelding 1 van 1
    • Remove the red and white wires from the rubber casing rim.
  7. Nortel Networks i2004 IP Buttons Replacement: stap 7, afbeelding 1 van 2 Nortel Networks i2004 IP Buttons Replacement: stap 7, afbeelding 2 van 2
    • Lift out the speaker and set it away from the tray that holds it.
    • Then remove the black plastic tray at the bottom by lifting it straight up.
  8. Nortel Networks i2004 IP Buttons Replacement: stap 8, afbeelding 1 van 1
    • Remove the two 8mm Phillips #2 screws.
  9. Nortel Networks i2004 IP Buttons Replacement: stap 9, afbeelding 1 van 2 Nortel Networks i2004 IP Buttons Replacement: stap 9, afbeelding 2 van 2
    • Pull the gray plastic casing away from the circuit board as you remove the clear, curved, plastic piece straight up.
  10. Nortel Networks i2004 IP Buttons Replacement: stap 10, afbeelding 1 van 3 Nortel Networks i2004 IP Buttons Replacement: stap 10, afbeelding 2 van 3 Nortel Networks i2004 IP Buttons Replacement: stap 10, afbeelding 3 van 3
    • There are three clips on the circuit board to un-clip.
    • Unclip both back black clips with your fingertips.
    • Push the middle black clip towards the bottom of the picture with a flathead screwdriver.
  11. Nortel Networks i2004 IP Buttons Replacement: stap 11, afbeelding 1 van 2 Nortel Networks i2004 IP Buttons Replacement: stap 11, afbeelding 2 van 2
    • There's a brown ribbon still attached to the circuit board and phone case, so don't pull the circuit board completely off just yet.
    • Lift the edge of the circuit board over the phone case and slightly up, so the bottom of circuit board can be viewed.
  12. Nortel Networks i2004 IP Buttons Replacement: stap 12, afbeelding 1 van 1
    • Push down each brown clip on either side of the brown metal strip using your fingertip.
    • Detach the circuit board from the brown ribbon.
  13. Nortel Networks i2004 IP Buttons Replacement: stap 13, afbeelding 1 van 1
    • Remove the clear rubber casing.
    • Be careful not to flip over the front phone casing or all of the buttons will fall out.
  14. Nortel Networks i2004 IP Buttons Replacement, Buttons: stap 14, afbeelding 1 van 1
    • Press the broken button from the front of the phone.
    • Remove the broken button through the back.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Andrew Wang
9 Reputatie
1 Handleiding geschreven
Cal Poly, Team 10-35, Amido Winter 2012 Lid van Cal Poly, Team 10-35, Amido Winter 2012
CPSU-AMIDO-W12S10G35
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 1,078
