Ga door naar hoofdinhoud
Nook Tablet Speaker Assembly Replacement
Wat je nodig hebt
  1. Nook Tablet Speaker Assembly Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Flip the Nook over.
  2. Nook Tablet Speaker Assembly Replacement: stap 2, afbeelding 1 van 2 Nook Tablet Speaker Assembly Replacement: stap 2, afbeelding 2 van 2
    • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
    • Remove the tape covering the round holes to reveal two T5 Torx screws.
    • Remove the two T5 Torx screws securing the back cover.
  3. Nook Tablet Speaker Assembly Replacement: stap 3, afbeelding 1 van 2 Nook Tablet Speaker Assembly Replacement: stap 3, afbeelding 2 van 2
    • Insert the flat end of a spudger between the front panel and the rear assembly.
    • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
    • Use a spudger to lift the the back panel from the rest of the Nook.
  4. Nook Tablet Speaker Assembly Replacement: stap 4, afbeelding 1 van 2 Nook Tablet Speaker Assembly Replacement: stap 4, afbeelding 2 van 2
    • Slide the spudger around the edges of the Nook to loosen the back panel.
  5. Nook Tablet Speaker Assembly Replacement: stap 5, afbeelding 1 van 1
    • Pull the back panel off the Nook.
  6. Nook Tablet Speaker Assembly Replacement, Screen Bezel: stap 6, afbeelding 1 van 2 Nook Tablet Speaker Assembly Replacement, Screen Bezel: stap 6, afbeelding 2 van 2
    • Using the T5 Torx screwdriver, remove the ten T5 screws from around the edges of the silver midframe.
  7. Nook Tablet Speaker Assembly Replacement: stap 7, afbeelding 1 van 2 Nook Tablet Speaker Assembly Replacement: stap 7, afbeelding 2 van 2
    • Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
  8. Nook Tablet Speaker Assembly Replacement, Disconnect the Battery: stap 8, afbeelding 1 van 2 Nook Tablet Speaker Assembly Replacement, Disconnect the Battery: stap 8, afbeelding 2 van 2
    • Lift up the foam pad at the corner of the battery to reveal the battery connector.
    • Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
    • These photos show a screwdriver, but we recommend using a nonconductive tool like a spudger to prevent a potential short.
  9. Nook Tablet Speaker Assembly Replacement, Midframe: stap 9, afbeelding 1 van 1
    • Lift up the foam that covers the power connector and volume connector.
    • Disconnect the power and volume cables from their sockets on the motherboard.
  10. Nook Tablet Speaker Assembly Replacement: stap 10, afbeelding 1 van 2 Nook Tablet Speaker Assembly Replacement: stap 10, afbeelding 2 van 2
    • Carefully lift the silver midframe away from the motherboard and display assembly.
    • Be careful when handling the motherboard, making sure to not dislodge/shift any of its major components.
  11. Nook Tablet Speaker Assembly Replacement, Removing Speaker Assembly: stap 11, afbeelding 1 van 1
    • Using your hands pull the square speaker assembly component off the motherboard.
  12. Nook Tablet Speaker Assembly Replacement, Replacing Speaker Assembly: stap 12, afbeelding 1 van 1
    • Now place the new speaker assembly component back in the same square location.
    • As Step 12 mentions, make sure to realign the speaker assembly correctly in the square.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Josh Fisher
9 Reputatie
1 Handleiding geschreven
Cal Poly, Team 1-4, Propen Fall 2012 Lid van Cal Poly, Team 1-4, Propen Fall 2012
CPSU-PROPEN-F12S1G4
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 2,117
