Ga door naar hoofdinhoud
Nook HD+ Speaker Replacement
Wat je nodig hebt
  1. Nook HD+ Speaker Replacement, Take off the Top Frame: stap 1, afbeelding 1 van 1
    • Wedge the plastic opening piece underneath the bottom left hand corner of the front frame
    • Pry open the front frame.
  2. Nook HD+ Speaker Replacement, Remove the screws: stap 2, afbeelding 1 van 2 Nook HD+ Speaker Replacement, Remove the screws: stap 2, afbeelding 2 van 2
    • Remove every visible screw tying the chassis to the bottom frame using a T-4 screwdriver bit.
  3. Nook HD+ Speaker Replacement, Remove the Battery: stap 3, afbeelding 1 van 2 Nook HD+ Speaker Replacement, Remove the Battery: stap 3, afbeelding 2 van 2
    • Carefully remove the bottom frame from center chassis.
    • Detach the battery ribbon from the motherboard.
    • Flip the center chaise onto the screen side with the hole positioned on the bottom right hand corner.
  4. Nook HD+ Speaker Replacement, Unscrew the speaker: stap 4, afbeelding 1 van 1
    • In the bottom left hand corner remove the 3 screws that at attached to the speaker
    • Disconnect the small red and black ribbon connected to the speaker from the white clip on the mother board.
    • Replace old speaker with new speaker then follow instructions in reverse order to reassemble
Conclusie
Alex Pelicas
283 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Lid van UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 Leden
10 handleidingen geschreven
Één opmerking
After purchasing a replacement speaker, these steps worked well. Process to a fairly relaxed 20 minutes.
The only thing I’d add is that the speaker is part # AAC121217U22A, and appears to be a bespoke part containing two speakers.
Knowing what part to look for may help others looking for a replacement part.
Jamal Taylor - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 730
