Inleiding
This guide tells you how to replace the battery on the Nook HD+ from Barnes & Noble.
Wat je nodig hebt
Wedge the plastic opening piece underneath the bottom left hand corner of the front frame. Pry the frame off of the Nook.
Remove every visible screw tying the chassis to the bottom frame using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
Apply glue to the bottom side of new battery. Re-insert new battery onto bottom frame and allow to dry. Follow steps in reverse to put nook back together.
12 andere personen hebben deze handleiding voltooid.
5 opmerkingen
Where i can buy new battery, or any similar [6000 mAh] ?
i have a Barnes and noble nook HD+ and how it won't charger at all.
