Inleiding
Steps to replace a broken speaker in the Nook HD+ tablet.
Onderdelen
Geen onderdelen nodig.
  1. Wedge the plastic opening piece underneath the bottom left hand corner of the front frame
    • Wedge the plastic opening piece underneath the bottom left hand corner of the front frame
      • Pry open the front frame.
  2. Remove every visible screw tying the chassis to the bottom frame using a T-4 screwdriver bit. Remove every visible screw tying the chassis to the bottom frame using a T-4 screwdriver bit.
    • Remove every visible screw tying the chassis to the bottom frame using a T-4 screwdriver bit.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  4. Carefully remove the bottom frame from center chassis. Detach the battery ribbon from the motherboard.
    • Carefully remove the bottom frame from center chassis.
    • Detach the battery ribbon from the motherboard.
    • Flip the center chaise onto the screen side with the hole positioned on the bottom right hand corner.
  5. In the bottom left hand corner remove the 3 screws that at attached to the speaker
    • In the bottom left hand corner remove the 3 screws that at attached to the speaker
    • Disconnect the small red and black ribbon connected to the speaker from the white clip on the mother board.
    • Replace old speaker with new speaker then follow instructions in reverse order to reassemble
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alex Pelicas
259 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 2-3, Duarte Fall 2014 Lid van UMass Dartmouth, Team 2-3, Duarte Fall 2014
UMASSD-DUARTE-F14S2G3
5 Leden
5 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 3
Altijd: 488
