Ga door naar hoofdinhoud
Nokia XL Dual Sim Front Camera Replacement
Wat je nodig hebt
  1. Nokia XL Dual Sim Front Camera Replacement, Back Cover Removal: stap 1, afbeelding 1 van 1
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
  2. Nokia XL Dual Sim Front Camera Replacement, Battery Removal: stap 2, afbeelding 1 van 2 Nokia XL Dual Sim Front Camera Replacement, Battery Removal: stap 2, afbeelding 2 van 2
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
  3. Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 1: stap 3, afbeelding 1 van 2 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 1: stap 3, afbeelding 2 van 2
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
  4. Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: stap 4, afbeelding 1 van 3 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: stap 4, afbeelding 2 van 3 Nokia XL Dual Sim Front Camera Replacement, Screen Separation part 2: stap 4, afbeelding 3 van 3
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
  5. Nokia XL Dual Sim Front Camera Replacement, System components: stap 5, afbeelding 1 van 1
    • Once the device is open, take note of all the components.
  6. Nokia XL Dual Sim Front Camera Replacement, Camera Removal: stap 6, afbeelding 1 van 3 Nokia XL Dual Sim Front Camera Replacement, Camera Removal: stap 6, afbeelding 2 van 3 Nokia XL Dual Sim Front Camera Replacement, Camera Removal: stap 6, afbeelding 3 van 3
    • With Tweezers, gently unsnap the front camera motherboard connector.
    • The front camera component can now be gently removed.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Shadeed Bilal
231 Reputatie
4 handleidingen geschreven
USF Tampa, Team 1-4, Brown Fall 2014 Lid van USF Tampa, Team 1-4, Brown Fall 2014
USFT-BROWN-F14S1G4
3 Leden
7 handleidingen geschreven
Één opmerking
merci 1000 fois pour ce cite
zmohye - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 1,043
