Ga door naar hoofdinhoud
Nokia N900 USB Replacement
Wat je nodig hebt
  1. Nokia N900 USB Replacement, USB: stap 1, afbeelding 1 van 1
    • Turn the phone over so the screen is face down.
  2. Nokia N900 USB Replacement: stap 2, afbeelding 1 van 2 Nokia N900 USB Replacement: stap 2, afbeelding 2 van 2
    • Remove the back cover by locating the slit on the bottom of the phone and lifting up.
  3. Nokia N900 USB Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery by lifting it out of the device.
  4. Nokia N900 USB Replacement: stap 4, afbeelding 1 van 2 Nokia N900 USB Replacement: stap 4, afbeelding 2 van 2
    • Remove the two "L-shaped" antennas by unscrewing the following screws:
    • Four screw M1 .4x5.0
    • Two screw RF1 .4x4
    • In addition to unscrewing the screws, remove the B-Cover (which will fall right out without the screws).
  5. Nokia N900 USB Replacement: stap 5, afbeelding 1 van 1
    • You will now have two halves of the phone.
    • Grab the half of the phone that has the keyboard on it
  6. Nokia N900 USB Replacement: stap 6, afbeelding 1 van 1
    • Remove the keyboard by unsnapping the frame and then lifting the pad out from the device.
    • Place the key pad and cover to the side for the remaining steps.
  7. Nokia N900 USB Replacement: stap 7, afbeelding 1 van 1
    • Use a blue plastic opening tool lift the motherboard out of the back cover
  8. Nokia N900 USB Replacement: stap 8, afbeelding 1 van 1
    • Look at the bottom of the motherboard to find the:
    • USB Port
    • Once you've located the USB Port you can search online or call the manufacturer to replace it.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Troy Posey
349 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 28
Altijd: 2,614
