Ga door naar hoofdinhoud
Nokia N900 Slider Assembly Replacement
Wat je nodig hebt
  1. Nokia N900 Slider Assembly Replacement, Slider Assembly: stap 1, afbeelding 1 van 1
    • Turn the phone over so the screen is face down.
  2. Nokia N900 Slider Assembly Replacement: stap 2, afbeelding 1 van 2 Nokia N900 Slider Assembly Replacement: stap 2, afbeelding 2 van 2
    • Remove the back cover by locating the slit on the bottom of the phone and lifting up.
  3. Nokia N900 Slider Assembly Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery by lifting it out of the device.
  4. Nokia N900 Slider Assembly Replacement: stap 4, afbeelding 1 van 2 Nokia N900 Slider Assembly Replacement: stap 4, afbeelding 2 van 2
    • Remove the two "L-shaped" antennas by unscrewing the following screws:
    • Four screw M1 .4x5.0
    • Two screw RF1 .4x4
    • In addition to unscrewing the screws, remove the B-Cover (which will fall right out without the screws).
  5. Nokia N900 Slider Assembly Replacement: stap 5, afbeelding 1 van 1
    • Turn the back of the phone over so the keyboard is face up. You should then have two halves of the phone.
    • To locate the slider, find the "black tape" on the screen half of the phone.
    • Weave the "slider tape" through the orange slot on the keyboard half of the phone.
    • Once you have completed these steps your phone should be able to slide up and down with ease.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Troy Posey
349 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 11
Altijd: 865
