Ga door naar hoofdinhoud
Nokia N70 Speaker Replacement
Wat je nodig hebt
  1. Nokia N70 Speaker Replacement, Battery: stap 1, afbeelding 1 van 1
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
  2. Nokia N70 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery cover by lifting it away from the phone.
  3. Nokia N70 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
  4. Nokia N70 Speaker Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery from the phone.
  5. Nokia N70 Speaker Replacement, Keypad: stap 5, afbeelding 1 van 3 Nokia N70 Speaker Replacement, Keypad: stap 5, afbeelding 2 van 3 Nokia N70 Speaker Replacement, Keypad: stap 5, afbeelding 3 van 3
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
  6. Nokia N70 Speaker Replacement: stap 6, afbeelding 1 van 3 Nokia N70 Speaker Replacement: stap 6, afbeelding 2 van 3 Nokia N70 Speaker Replacement: stap 6, afbeelding 3 van 3
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
  7. Nokia N70 Speaker Replacement, Speaker: stap 7, afbeelding 1 van 2 Nokia N70 Speaker Replacement, Speaker: stap 7, afbeelding 2 van 2
    • Use the T6 Torx screwdriver to remove the six 15 mm Torx screws.
  8. Nokia N70 Speaker Replacement: stap 8, afbeelding 1 van 3 Nokia N70 Speaker Replacement: stap 8, afbeelding 2 van 3 Nokia N70 Speaker Replacement: stap 8, afbeelding 3 van 3
    • Lift the bottom edge of the front panel at a 45 degree angle.
    • Remove front panel by slowly pulling it away from the phone at a 45 degree angle.
  9. Nokia N70 Speaker Replacement: stap 9, afbeelding 1 van 3 Nokia N70 Speaker Replacement: stap 9, afbeelding 2 van 3 Nokia N70 Speaker Replacement: stap 9, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Locate the speaker location located on the back panel of the phone.
    • Using the tweezers place one side of tweezers in the rectangular slot where the speaker is located
    • Slowly lift speaker away from the back panel.
Conclusie
Justin
984 Reputatie
5 handleidingen geschreven
Cal Poly, Team 6-2, Regan Fall 2011 Lid van Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 4,105
