Ga door naar hoofdinhoud
Nokia N70 Back Camera Replacement
Wat je nodig hebt
  1. Nokia N70 Back Camera Replacement, Battery: stap 1, afbeelding 1 van 1
    • Orient the phone as shown.
    • Press the button with the plastic opening tool and slide the back case downward relative to the phone.
  2. Nokia N70 Back Camera Replacement: stap 2, afbeelding 1 van 1
    • Remove the battery cover by lifting it away from the phone.
  3. Nokia N70 Back Camera Replacement: stap 3, afbeelding 1 van 1
    • Insert the plastic opening tool into the marked space.
    • Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
  4. Nokia N70 Back Camera Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery from the phone.
  5. Nokia N70 Back Camera Replacement, Keypad: stap 5, afbeelding 1 van 3 Nokia N70 Back Camera Replacement, Keypad: stap 5, afbeelding 2 van 3 Nokia N70 Back Camera Replacement, Keypad: stap 5, afbeelding 3 van 3
    • Insert the plastic opening tool in the marked areas in between the front and back covers.
    • Pry each corner with the plastic opening tool until the front case completely detaches.
  6. Nokia N70 Back Camera Replacement: stap 6, afbeelding 1 van 3 Nokia N70 Back Camera Replacement: stap 6, afbeelding 2 van 3 Nokia N70 Back Camera Replacement: stap 6, afbeelding 3 van 3
    • Orient the phone so that the keypad is facing you.
    • Remove the keypad by lifting it away from the phone.
  7. Nokia N70 Back Camera Replacement, Back Camera: stap 7, afbeelding 1 van 2 Nokia N70 Back Camera Replacement, Back Camera: stap 7, afbeelding 2 van 2
    • Using T6 Torx screwdriver remove the six 15 mm torx screws.
  8. Nokia N70 Back Camera Replacement: stap 8, afbeelding 1 van 3 Nokia N70 Back Camera Replacement: stap 8, afbeelding 2 van 3 Nokia N70 Back Camera Replacement: stap 8, afbeelding 3 van 3
    • Separate the front panel from the back by lifting the bottom of the front panel at a 45 degree angle.
    • Remove the front panel by lifting the panel away from the phone at a 45 degree angle.
  9. Nokia N70 Back Camera Replacement: stap 9, afbeelding 1 van 3 Nokia N70 Back Camera Replacement: stap 9, afbeelding 2 van 3 Nokia N70 Back Camera Replacement: stap 9, afbeelding 3 van 3
    • Locate the rear circuit board by flipping over the front panel.
    • Locate the rear camera and by using the plastic opening tool, gently lift the camera out of the slot.
    • Caution: Be careful when prying camera out of the slot for the connections are fragile.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Justin
984 Reputatie
5 handleidingen geschreven
Cal Poly, Team 6-2, Regan Fall 2011 Lid van Cal Poly, Team 6-2, Regan Fall 2011
CPSU-REGAN-F11S6G2
4 Leden
10 handleidingen geschreven
Één opmerking
mon nokia n70 est mal camera alors quest -ce qu*on va faire
sidiahmed ahmed - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 8,827
