Ga door naar hoofdinhoud
Nokia Lumia 930 Battery Replacement
Wat je nodig hebt
  1. Nokia Lumia 930 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Pull the SIM card holder out of the top of the phone using your fingernail.
  2. Nokia Lumia 930 Battery Replacement: stap 2, afbeelding 1 van 2 Nokia Lumia 930 Battery Replacement: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Place tweezers or an opening tool in the SIM card slot and push upwards until the back panel pops out.
  3. Nokia Lumia 930 Battery Replacement: stap 3, afbeelding 1 van 2 Nokia Lumia 930 Battery Replacement: stap 3, afbeelding 2 van 2
    • Wedge a plastic opening tool between the two panels. Slide it along each side of the phone to completely remove the back panel.
  4. Nokia Lumia 930 Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the 4mm Torx #4 screw that's securing the battery connector.
  5. Nokia Lumia 930 Battery Replacement: stap 5, afbeelding 1 van 1
    • Use tweezers to remove the battery connector strap.
  6. Nokia Lumia 930 Battery Replacement: stap 6, afbeelding 1 van 2 Nokia Lumia 930 Battery Replacement: stap 6, afbeelding 2 van 2
    • Remove all ten 4mm Torx #4 screws that secure the battery cover to the frame of the phone.
  7. Nokia Lumia 930 Battery Replacement: stap 7, afbeelding 1 van 3 Nokia Lumia 930 Battery Replacement: stap 7, afbeelding 2 van 3 Nokia Lumia 930 Battery Replacement: stap 7, afbeelding 3 van 3
    • Use the flat end of a spudger to pry the battery cover from the phone's frame.
  8. Nokia Lumia 930 Battery Replacement: stap 8, afbeelding 1 van 1
    • Pull up on the heat spreader.
    • Be careful not to tear it!
  9. Nokia Lumia 930 Battery Replacement: stap 9, afbeelding 1 van 1
    • Use the flat end of the spudger to lift up the battery.
    • The battery is glued in place. Pry up carefully, not to damage it.
    • Two flex cables are directly underneath the battery.
  10. Nokia Lumia 930 Battery Replacement: stap 10, afbeelding 1 van 1
    • Remove the battery from the phone.
Conclusie
3 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 32
Altijd: 5,816
