Wat je nodig hebt
Stap 1 Opening The Phone
Voorzichtig: stap 1 komt van een handleiding die in bewerking is.
Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
Using the opening tool, pry the screen from the casing until they are separated from each other.
Apply adhesive to back of camera
Attach ribbon to motherboard
Press down on camera for 60 seconds
Let dry for 5 minutes
Slide the hinges of the left side of the screen under the left side of the plastic case
Clamp the right side of the screen down and make sure screen is flat
The screen should "click" into place
Één andere persoon heeft deze handleiding voltooid.
