Inleiding
The front camera is an integral part of the Nokia Lumia 900. Because it is a small and delicate component, this guide will show how to remove it carefully and properly.
Wat je nodig hebt
Insert the pointed end of the spudger into the sim card port indicated by the picture. Then proceed to remove the sim card port entirely.
Use the iFixit iOpener or another heat source to gently heat the top left corner until the adhesive under the camera softens.
Use the plastic opening tools to carefully lift the front camera from the motherboard.
