Ga door naar hoofdinhoud
Nokia Lumia 830 Main Speaker Replacement
Wat je nodig hebt
  1. Nokia Lumia 830 Main Speaker Replacement, Battery: stap 1, afbeelding 1 van 2 Nokia Lumia 830 Main Speaker Replacement, Battery: stap 1, afbeelding 2 van 2
    • Place the phone with the screen facing down.
    • Remove the back cover by placing your fingernail or plastic opening tool under the slotted indent at the bottom of the phone.
  2. Nokia Lumia 830 Main Speaker Replacement: stap 2, afbeelding 1 van 3 Nokia Lumia 830 Main Speaker Replacement: stap 2, afbeelding 2 van 3 Nokia Lumia 830 Main Speaker Replacement: stap 2, afbeelding 3 van 3
    • Carefully remove the battery by placing the plastic opening tool underneath the indent at the bottom of the battery, and pry it up.
    • There may be adhesive underneath the battery to keep it in place, this may make it a bit difficult to remove the battery.
  3. Nokia Lumia 830 Main Speaker Replacement, Main Speaker: stap 3, afbeelding 1 van 2 Nokia Lumia 830 Main Speaker Replacement, Main Speaker: stap 3, afbeelding 2 van 2
    • Remove the black strips on both sides of the battery compartment.
  4. Nokia Lumia 830 Main Speaker Replacement: stap 4, afbeelding 1 van 2 Nokia Lumia 830 Main Speaker Replacement: stap 4, afbeelding 2 van 2
    • Remove the two 3.9mm silver screws from the bottom corner of the phone. Then remove the five 2.5mm black screws from top to bottom of the phone.
    • All of the screws take a t5 star screwdriver.
  5. Nokia Lumia 830 Main Speaker Replacement: stap 5, afbeelding 1 van 3 Nokia Lumia 830 Main Speaker Replacement: stap 5, afbeelding 2 van 3 Nokia Lumia 830 Main Speaker Replacement: stap 5, afbeelding 3 van 3
    • Use the plastic opening tool to push into the slots holding the backing in place.
    • All five slots are along the inner wall of the battery compartment. Push the slots on the sides first before pushing the slot on the top.
    • Remove the backing from the frame, making sure to lift the bottom portion away from the phone, to allow the top to slide out of place.
  6. Nokia Lumia 830 Main Speaker Replacement: stap 6, afbeelding 1 van 1
    • Lift the speaker out of the phone. You may need to wiggle the speaker loose.
Conclusie
saydeking
527 Reputatie
4 handleidingen geschreven
USF Tampa, Team 1-2, Sullivan Fall 2016 Lid van USF Tampa, Team 1-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G2
3 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 877
