Ga door naar hoofdinhoud
Nokia Lumia 830 Battery Replacement
Wat je nodig hebt
  1. Nokia Lumia 830 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Nokia Lumia 830 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Place the phone with the screen facing down.
    • Remove the back cover by placing your fingernail or plastic opening tool under the slotted indent at the bottom of the phone.
  2. Nokia Lumia 830 Battery Replacement: stap 2, afbeelding 1 van 3 Nokia Lumia 830 Battery Replacement: stap 2, afbeelding 2 van 3 Nokia Lumia 830 Battery Replacement: stap 2, afbeelding 3 van 3
    • Carefully remove the battery by placing the plastic opening tool underneath the indent at the bottom of the battery, and pry it up.
    • There may be adhesive underneath the battery to keep it in place, this may make it a bit difficult to remove the battery.
Conclusie
Adam Mack
284 Reputatie
2 handleidingen geschreven
USF Tampa, Team 1-2, Sullivan Fall 2016 Lid van USF Tampa, Team 1-2, Sullivan Fall 2016
USFT-SULLIVAN-F16S1G2
3 Leden
11 handleidingen geschreven
Één opmerking
Hi, i’ve bought a battery from amazon to this phone. It has the same specs as the old one, but when i put it to charge (on the phone) it only charges untill half and it stays there. Do i need to buy a different battery or is there a way to fix this?
Eduardo Teixeira - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 8
Altijd: 1,397
