1. Check condition of switches on logicboard
    • Check condition of switches on logicboard
    • Rule out failure of cover
  2. Torx 6 screwdriver
    • Torx 6 screwdriver
    • Soldering iron (thin tip)
    • Decent quality solder (thin wire)
  3. Remove cover, battery and SIM
    • Remove cover, battery and SIM
    • Remove 6 torx screws
    • Note: Green is fine thread
    • Note: Red is coarse thread
  4. Remove plastic clover near battery Keep track of all parts
    • Remove plastic clover near battery
    • Keep track of all parts
  5. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  6. Gently release logicboard connectors
    • Gently release logicboard connectors
  7. There is a clip that needs to be moved out of the way before the board will move. Start by lifting long side of logicboard
    • There is a clip that needs to be moved out of the way before the board will move.
    • Start by lifting long side of logicboard
    • Gently wiggle and lift
    • Undo plastic clips near battery with force
  8. Check connections of failed buttons
    • Check connections of failed buttons
  9. Resolder broken connections
    • Resolder broken connections
    • Make sure the pads do not short
  10. Put back logicboard
    • Put back logicboard
    • Make sure pins near camera line-up
    • Note: Plastic clips need quite some force
  11. Reconnect logicboard connectors
    • Reconnect logicboard connectors
  12. Put back plastic cover
    • Put back plastic cover
  13. Gently tighten screws
    • Gently tighten screws
    • Put back SIM card and battery
    • Close cover
    • Enjoy the result ;)
Eindstreep
11 andere personen hebben deze handleiding voltooid.
Anne
456 Reputatie
1 Handleiding geschreven
Realmente funcionó el tutorial, sirven de nuevo los dos botones que fallaban.
Gaia501 - Antwoord
Only the 2 middle screws are fine threaded. And you can see in the pictures here, that there are 4 coarse threaded ones and 2 fine threaded ones. The green one in the corner should be red
shadow118 - Antwoord
hafıza kart okuyucu çalışmıyor ne yapmam lazım
davutcigir - Antwoord
Omg it looks complicated
Maz Hanvey - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 9
Afgelopen 30 Dagen: 28
Altijd: 9,555
