Ga door naar hoofdinhoud
Onderdelen
  1. Deze stap is niet vertaald. Help het te vertalen
    The first thing you'll need is a Nokia Lumia 610 with a broken front glass
    • The first thing you'll need is a Nokia Lumia 610 with a broken front glass
  2. Deze stap is niet vertaald. Help het te vertalen
    Slide the back cover off, and remove the battery Slide the back cover off, and remove the battery
    • Slide the back cover off, and remove the battery
  3. Deze stap is niet vertaald. Help het te vertalen
    There are 8 Torx 5 screws you have to remove, 4 on each side There are 8 Torx 5 screws you have to remove, 4 on each side
    • There are 8 Torx 5 screws you have to remove, 4 on each side
  4. Deze stap is niet vertaald. Help het te vertalen
    After removing all 8 screws, proceed to prying off the back cover This is done very easily, by prying it from the 3 grooves depicted This step might also be done using your nails, as the clips are not strong at all
    • After removing all 8 screws, proceed to prying off the back cover
    • This is done very easily, by prying it from the 3 grooves depicted
    • This step might also be done using your nails, as the clips are not strong at all
  5. Deze stap is niet vertaald. Help het te vertalen
    Watch out - the buttons easily fall out; just make sure you don't loose any, a'aight ?!
    • Watch out - the buttons easily fall out; just make sure you don't loose any, a'aight ?!
  6. Deze stap is niet vertaald. Help het te vertalen
    Lift the back cover up, and pull it back - most likely, the 2 sided tape sealing the camera module will be the last thing to break loose Make sure you stick it back to the rear case assembly after this step
    • Lift the back cover up, and pull it back - most likely, the 2 sided tape sealing the camera module will be the last thing to break loose
    • Make sure you stick it back to the rear case assembly after this step
  7. Deze stap is niet vertaald. Help het te vertalen
    Disconnect the 2 ribbon cables connecting the LCD & Digitizer to the motherboard Disconnect the 2 ribbon cables connecting the LCD & Digitizer to the motherboard Disconnect the 2 ribbon cables connecting the LCD & Digitizer to the motherboard
    • Disconnect the 2 ribbon cables connecting the LCD & Digitizer to the motherboard
  8. Deze stap is niet vertaald. Help het te vertalen
    Now to separate the Motherboard from the front assembly !
    • Now to separate the Motherboard from the front assembly !
    • Gently pry on the 2 hooks depicted in the picture to release the motherboard
    • Again - using your nails should be just fine !
  9. Deze stap is niet vertaald. Help het te vertalen
    Lift the motherboard up from the back, and pull it backwards Apply the same motion as with the back casing
    • Lift the motherboard up from the back, and pull it backwards
    • Apply the same motion as with the back casing
    • You should now have separated the motherboard from the LCD/Digitizer Assembly
  10. Deze stap is niet vertaald. Help het te vertalen
    To detach the LCD, gently lift it from the sides - be careful, and don't pull too hard on the ribbon cable ! It's secured in with pretty weak double-sided tape, so this step shouldn't be a problem
    • To detach the LCD, gently lift it from the sides - be careful, and don't pull too hard on the ribbon cable !
    • It's secured in with pretty weak double-sided tape, so this step shouldn't be a problem
  11. Deze stap is niet vertaald. Help het te vertalen
    Remove the ear-piece speaker from the Digitizer Assembly It's held in by - again - pretty weak double-sided tape
    • Remove the ear-piece speaker from the Digitizer Assembly
    • It's held in by - again - pretty weak double-sided tape
    • 2nd picture gives you a look of the front of the speaker unit - it's pretty hard to damage the membrane - though, you can never be too careful !
  12. Deze stap is niet vertaald. Help het te vertalen
    Something very easy to forget - remove the tiny rubber gasket for the microphone, and place it in the new front panel Something very easy to forget - remove the tiny rubber gasket for the microphone, and place it in the new front panel
    • Something very easy to forget - remove the tiny rubber gasket for the microphone, and place it in the new front panel
  13. Deze stap is niet vertaald. Help het te vertalen
    To put everything back together, just follow the same steps backward, and you should have yourself a good-as-new Nokia Lumia 610
    • To put everything back together, just follow the same steps backward, and you should have yourself a good-as-new Nokia Lumia 610
    • The last step in this guide - is trying not to break it again :)
Eindstreep
6 andere personen hebben deze handleiding voltooid.
Darie H
4.474 Reputatie
5 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 5,525
