Ga door naar hoofdinhoud
Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement
Wat je nodig hebt
  1. Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement, Touchscreen Glass / Digitizer Assembly: stap 1, afbeelding 1 van 1
    • The first thing you'll need is a Nokia Lumia 610 with a broken front glass
  2. Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement: stap 2, afbeelding 1 van 2 Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement: stap 2, afbeelding 2 van 2
    • Slide the back cover off, and remove the battery
  3. Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement: stap 3, afbeelding 1 van 2 Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement: stap 3, afbeelding 2 van 2
    • There are 8 Torx 5 screws you have to remove, 4 on each side
  4. Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement: stap 4, afbeelding 1 van 3 Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement: stap 4, afbeelding 2 van 3 Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement: stap 4, afbeelding 3 van 3
    • After removing all 8 screws, proceed to prying off the back cover
    • This is done very easily, by prying it from the 3 grooves depicted
    • This step might also be done using your nails, as the clips are not strong at all
  5. Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement: stap 5, afbeelding 1 van 1
    • Watch out - the buttons easily fall out; just make sure you don't loose any, a'aight ?!
  6. Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement: stap 6, afbeelding 1 van 2 Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement: stap 6, afbeelding 2 van 2
    • Lift the back cover up, and pull it back - most likely, the 2 sided tape sealing the camera module will be the last thing to break loose
    • Make sure you stick it back to the rear case assembly after this step
  7. Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement: stap 7, afbeelding 1 van 3 Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement: stap 7, afbeelding 2 van 3 Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement: stap 7, afbeelding 3 van 3
    • Disconnect the 2 ribbon cables connecting the LCD & Digitizer to the motherboard
  8. Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement: stap 8, afbeelding 1 van 1
    • Now to separate the Motherboard from the front assembly !
    • Gently pry on the 2 hooks depicted in the picture to release the motherboard
    • Again - using your nails should be just fine !
  9. Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement: stap 9, afbeelding 1 van 2 Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement: stap 9, afbeelding 2 van 2
    • Lift the motherboard up from the back, and pull it backwards
    • Apply the same motion as with the back casing
    • You should now have separated the motherboard from the LCD/Digitizer Assembly
  10. Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement: stap 10, afbeelding 1 van 2 Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement: stap 10, afbeelding 2 van 2
    • To detach the LCD, gently lift it from the sides - be careful, and don't pull too hard on the ribbon cable !
    • It's secured in with pretty weak double-sided tape, so this step shouldn't be a problem
  11. Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement: stap 11, afbeelding 1 van 2 Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement: stap 11, afbeelding 2 van 2
    • Remove the ear-piece speaker from the Digitizer Assembly
    • It's held in by - again - pretty weak double-sided tape
    • 2nd picture gives you a look of the front of the speaker unit - it's pretty hard to damage the membrane - though, you can never be too careful !
  12. Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement: stap 12, afbeelding 1 van 2 Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement: stap 12, afbeelding 2 van 2
    • Something very easy to forget - remove the tiny rubber gasket for the microphone, and place it in the new front panel
  13. Nokia Lumia 610 Touchscreen Glass / Digitizer Assembly Replacement: stap 13, afbeelding 1 van 1
    • To put everything back together, just follow the same steps backward, and you should have yourself a good-as-new Nokia Lumia 610
    • The last step in this guide - is trying not to break it again :)
Conclusie
8 andere personen hebben deze handleiding voltooid.
Darie H
4.671 Reputatie
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 23
Altijd: 6,029
