Ga door naar hoofdinhoud
Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement
Wat je nodig hebt
Video overzicht
  1. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement, Touch screen / Digitizer, LCD Display: stap 1, afbeelding 1 van 2 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement, Touch screen / Digitizer, LCD Display: stap 1, afbeelding 2 van 2
    • Switch off the phone and remove the battery.
  2. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: stap 2, afbeelding 1 van 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: stap 2, afbeelding 2 van 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: stap 2, afbeelding 3 van 3
    • Remove 8x Torx T5 screws.
    • With a plastic tool, start with separating the middle frame from the down side.
  3. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: stap 3, afbeelding 1 van 2 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: stap 3, afbeelding 2 van 2
    • The Loudspeaker is on the middle frame.
    • Disconnect the LCD Display flex cable.
    • Disconnect the Touch screen flex cable.
  4. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: stap 4, afbeelding 1 van 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: stap 4, afbeelding 2 van 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: stap 4, afbeelding 3 van 3
    • The Logic board is held by 2x locking clips at the bottom side.
    • Release it and gently remove it from the front frame.
  5. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: stap 5, afbeelding 1 van 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: stap 5, afbeelding 2 van 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: stap 5, afbeelding 3 van 3
    • Put tape on the glass to not scatter pieces.
    • Worm the glass to melt the adhesive.
    • Use plastic tools to separate the touchscreen from the frame.
  6. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: stap 6, afbeelding 1 van 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: stap 6, afbeelding 2 van 3 Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: stap 6, afbeelding 3 van 3
    • After separating, clean up the sticker that remains on the borders.
    • New line.Install the new touchscreen and reassemble the device.
  7. Nokia Lumia 610 Touch screen / Digitizer, LCD Display Replacement: stap 7, afbeelding 1 van 1
    • That's all.
    • Did you do it successfully?
Conclusie
4 andere personen hebben deze handleiding voltooid.
ZFix
196.358 Reputatie
330 handleidingen geschreven
Master Techs Lid van Master Techs
Community
332 Leden
1.473 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 2,095
