Ga door naar hoofdinhoud
Nokia Lumia 520 Battery Replacement
Wat je nodig hebt
  1. Nokia Lumia 520 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Nokia Lumia 520 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Insert the spudger into the crevice located between the back cover of the phone and the body of the phone.
  2. Nokia Lumia 520 Battery Replacement: stap 2, afbeelding 1 van 2 Nokia Lumia 520 Battery Replacement: stap 2, afbeelding 2 van 2
    • Lift the spudger gently to open the back cover of the phone.
  3. Nokia Lumia 520 Battery Replacement: stap 3, afbeelding 1 van 2 Nokia Lumia 520 Battery Replacement: stap 3, afbeelding 2 van 2
    • Insert the spudger into the space between the batter and the battery holder to remove the battery.
Conclusie
Kobina Faibille
156 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 1-5, Bhusal Fall 2015 Lid van UMass Dartmouth, Team 1-5, Bhusal Fall 2015
UMASSD-BHUSAL-F15S1G5
3 Leden
8 handleidingen geschreven
2 opmerkingen
First off you don t need any tools to open this device, secondly you may damage the sim board in section 2 of this tutorial.There is a ) at the bottom of thephone to easily remove the battery.Use your fingers to gently push open the cover at the corners of the phone changing battery takes 1 minte.
beerwings1776 - Antwoord
Greetings I have a Lumia & I need the Screen and Battery,so how can I get those 2?
Ayoba - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 40
Altijd: 3,671
