Ga door naar hoofdinhoud
Nokia Lumia 1020 Front-Facing Camera Replacement
Wat je nodig hebt
  1. Nokia Lumia 1020 Front-Facing Camera Replacement, Screen: stap 1, afbeelding 1 van 2 Nokia Lumia 1020 Front-Facing Camera Replacement, Screen: stap 1, afbeelding 2 van 2
    • Use a SIM door key to remove the SIM card and SIM card tray from the device.
    • Use a T4 screwdriver to loosen the captured torx screw to the right of the SIM card tray (the screw will not come out).
  2. Nokia Lumia 1020 Front-Facing Camera Replacement: stap 2, afbeelding 1 van 3 Nokia Lumia 1020 Front-Facing Camera Replacement: stap 2, afbeelding 2 van 3 Nokia Lumia 1020 Front-Facing Camera Replacement: stap 2, afbeelding 3 van 3
    • Wedge a spudger in between the screen and the back of the device, starting from the top left corner of the phone.
    • Gently pry the screen away from the back of the device using slight upward pressure.
    • Slide the spudger down towards the bottom left corner of the device, continuing to gently pry upwards. The screen will now be slightly separated from the back of the phone.
  3. Nokia Lumia 1020 Front-Facing Camera Replacement: stap 3, afbeelding 1 van 3 Nokia Lumia 1020 Front-Facing Camera Replacement: stap 3, afbeelding 2 van 3 Nokia Lumia 1020 Front-Facing Camera Replacement: stap 3, afbeelding 3 van 3
    • Wedge a spudger underneath the silver rectangle in the upper right corner until it pops off the back of the phone.
  4. Nokia Lumia 1020 Front-Facing Camera Replacement: stap 4, afbeelding 1 van 3 Nokia Lumia 1020 Front-Facing Camera Replacement: stap 4, afbeelding 2 van 3 Nokia Lumia 1020 Front-Facing Camera Replacement: stap 4, afbeelding 3 van 3
    • Wedge a spudger underneath the silver rectangle in the lower left corner until it pops off the back of the phone.
    • Completely remove the screen from the back of the phone.
  5. Nokia Lumia 1020 Front-Facing Camera Replacement, Front-Facing Camera: stap 5, afbeelding 1 van 3 Nokia Lumia 1020 Front-Facing Camera Replacement, Front-Facing Camera: stap 5, afbeelding 2 van 3 Nokia Lumia 1020 Front-Facing Camera Replacement, Front-Facing Camera: stap 5, afbeelding 3 van 3
    • Wedge a spudger underneath front-facing camera on the upper left corner of the screen. Pry upwards until it pops up to the right.
  6. Nokia Lumia 1020 Front-Facing Camera Replacement: stap 6, afbeelding 1 van 3 Nokia Lumia 1020 Front-Facing Camera Replacement: stap 6, afbeelding 2 van 3 Nokia Lumia 1020 Front-Facing Camera Replacement: stap 6, afbeelding 3 van 3
    • Wedge a spudger underneath the silver rectangle to the right of the front-facing camera. Pry upwards until it pops off.
    • Remove the camera.
Conclusie
Sydney Hostelley
614 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G4, Leahy Spring 2018 Lid van USF Tampa, Team S1-G4, Leahy Spring 2018
USFT-LEAHY-S18S1G4
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 423
