Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Wat je nodig hebt
Start with the phone in the flipped open position.
You must remove the sticker in the center, below the screen to reveal the center screw.
Use a T5 screwdriver to remove all three screws, loosening the front screen.
With the front cover off, the screen and keypad should be loose.
After removing the front screen and front keypad, your device should look like this.
In order to install a new screen, simply follow the steps in reverse order with the new screen.
4 andere personen hebben deze handleiding voltooid.
