Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
If your front screen has stopped working and you need a new one, this guide will show you how to access the front screen.
Wat je nodig hebt
Start with the phone in the flipped open position.
You must remove the sticker in the center, below the screen to reveal the center screw.
Use a T5 screwdriver to remove all three screws, loosening the front screen.
With the front cover off, the screen and keypad should be loose.
In order to reassemble the front screen or install a new screen, follow the steps provided, in reverse order.
Één andere persoon heeft deze handleiding voltooid.
