Ga door naar hoofdinhoud
Nokia E61i Headset Jack Replacement
Wat je nodig hebt
  1. Nokia E61i Headset Jack Replacement, Battery: stap 1, afbeelding 1 van 2 Nokia E61i Headset Jack Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the back cover to access the battery. Press the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing the tab down.
  2. Nokia E61i Headset Jack Replacement: stap 2, afbeelding 1 van 1
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Nokia E61i Headset Jack Replacement: stap 3, afbeelding 1 van 1
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Nokia E61i Headset Jack Replacement, Front Cover: stap 4, afbeelding 1 van 2 Nokia E61i Headset Jack Replacement, Front Cover: stap 4, afbeelding 2 van 2
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Nokia E61i Headset Jack Replacement: stap 5, afbeelding 1 van 1
    • Remove the cover by pulling it up and off.
  6. Nokia E61i Headset Jack Replacement, Display: stap 6, afbeelding 1 van 2 Nokia E61i Headset Jack Replacement, Display: stap 6, afbeelding 2 van 2
    • Take off the casing and keyboard.
    • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
    • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
    • Lift the ribbon off of the contact with the motherboard.
    • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
  7. Nokia E61i Headset Jack Replacement: stap 7, afbeelding 1 van 2 Nokia E61i Headset Jack Replacement: stap 7, afbeelding 2 van 2
    • Gently pull the screen off of the phone.
    • Be sure not to rip the sticker that connects the display and the motherboard.
    • Pull the silver case off to completely free the cracked or damaged screen.
  8. Nokia E61i Headset Jack Replacement, Motherboard: stap 8, afbeelding 1 van 3 Nokia E61i Headset Jack Replacement, Motherboard: stap 8, afbeelding 2 van 3 Nokia E61i Headset Jack Replacement, Motherboard: stap 8, afbeelding 3 van 3
    • Pull the green motherboard from the back casing.
  9. Nokia E61i Headset Jack Replacement, Connector Housing: stap 9, afbeelding 1 van 1
    • Remove the connector housing by pushing and sliding it off the back panel.
    • Be very careful not to lose the small loose spring from behind the button or the small button itself.
  10. Nokia E61i Headset Jack Replacement, Headset Jack: stap 10, afbeelding 1 van 1
    • Remove the headset jack from the housing by pulling it up.
Conclusie
Christopher Patton
208 Reputatie
12 handleidingen geschreven
Cal Poly, Team 9-63, Walters Spring 2011 Lid van Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
5 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 2,704
