Ga door naar hoofdinhoud
Nokia Classic 2600c-2b Camera Replacement
Wat je nodig hebt
  1. Nokia Classic 2600c-2b Camera Replacement, Camera: stap 1, afbeelding 1 van 2 Nokia Classic 2600c-2b Camera Replacement, Camera: stap 1, afbeelding 2 van 2
    • Press down on the button located at the bottom of the phone, using the center ridge as a guide.
    • Pull the phone apart from the bottom, keeping the button pressed down.
    • CAUTION! The plastic opening tool may be used to gain leverage. Some force is required to open.
  2. Nokia Classic 2600c-2b Camera Replacement: stap 2, afbeelding 1 van 1
    • Remove the back cover to expose the battery. Put the plastic cover in a safe location for later.
  3. Nokia Classic 2600c-2b Camera Replacement: stap 3, afbeelding 1 van 2 Nokia Classic 2600c-2b Camera Replacement: stap 3, afbeelding 2 van 2
    • Place a finger or plastic opening tool in the gap between the battery and the phone.
    • Gently lift the battery out by putting your finger in the small indent.
  4. Nokia Classic 2600c-2b Camera Replacement: stap 4, afbeelding 1 van 2 Nokia Classic 2600c-2b Camera Replacement: stap 4, afbeelding 2 van 2
    • Locate the plastic latches on the left and right sides of the phone.
    • Insert the plastic opening tool or a fingernail into each latch and pry them open individually.
    • CAUTION! Some force is required.
  5. Nokia Classic 2600c-2b Camera Replacement: stap 5, afbeelding 1 van 1
    • Remove the faceplate with the number pad attached and put the faceplate to the side.
  6. Nokia Classic 2600c-2b Camera Replacement: stap 6, afbeelding 1 van 1
    • Turn the faceplate so the number pad faces downward.
    • Lift the number pad out of the faceplate.
  7. Nokia Classic 2600c-2b Camera Replacement: stap 7, afbeelding 1 van 2 Nokia Classic 2600c-2b Camera Replacement: stap 7, afbeelding 2 van 2
    • Remove the six screws along the edges of the phone using a Torx 5 screwdriver.
  8. Nokia Classic 2600c-2b Camera Replacement: stap 8, afbeelding 1 van 2 Nokia Classic 2600c-2b Camera Replacement: stap 8, afbeelding 2 van 2
    • Locate the orange ribbon tape connecting the metal display plate to the motherboard.
    • Lift the black latch attaching the tape to the motherboard.
    • Gently pull the tape out of the latch slot to remove the metal display.
  9. Nokia Classic 2600c-2b Camera Replacement: stap 9, afbeelding 1 van 2 Nokia Classic 2600c-2b Camera Replacement: stap 9, afbeelding 2 van 2
    • Using the plastic opening tool, gently pry off the motherboard from the plastic shell. Place the metal display in a safe location for reassembly.
    • CAUTION! When pulling the motherboard out, be careful not to damage the battery under the lower left hand corner of the motherboard.
  10. Nokia Classic 2600c-2b Camera Replacement: stap 10, afbeelding 1 van 1
    • Turn the motherboard over and locate the orange ribbon tape connecting the display to the motherboard.
    • Gently pull the tape up to remove the display.
  11. Nokia Classic 2600c-2b Camera Replacement: stap 11, afbeelding 1 van 1
    • Locate the camera component in the plastic shell removed from underneath the motherboard (It is one piece).
    • Gently pull out the camera component using either a finger or plastic opening tool.
Conclusie
Ian VanZandt
654 Reputatie
5 handleidingen geschreven
James Madison, Team 3-1, Klein Spring 2012 Lid van James Madison, Team 3-1, Klein Spring 2012
JMU-KLEIN-S12S3G1
3 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 1,272
