Ga door naar hoofdinhoud
Inleiding
How to remove the keypad.
Onderdelen
Geen onderdelen opgegeven.
  1. Turn off the cell phone.
    • Turn off the cell phone.
  2. Press down on the round button on the back cover of the phone.
    • Press down on the round button on the back cover of the phone.
  3. Slide the back cover down while still pressing the button.
    • Slide the back cover down while still pressing the button.
  4. Remove the back cover.
    • Remove the back cover.
  5. Press the end of the battery towards the top of the phone.
    • Press the end of the battery towards the top of the phone.
  6. Lift the battery outwards while still pressing it upwards till it pops out.
    • Lift the battery outwards while still pressing it upwards till it pops out.
    • You may need to take several attempts to lift out the battery.
  7. iPhone Batterij Fix Kits
    Slechts $29.99
    Buy Now
    Slechts $29.99
    Buy Now
  8. Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
    • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
    • This step may be a bit difficult if you are removing the antenna for the first time.
  9. Pry open the antenna door by pulling down the top of the spudger
    • Pry open the antenna door by pulling down the top of the spudger
  10. Remove the antenna door.
    • Remove the antenna door.
  11. If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
    • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
    • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
    • Try to keep the antenna as flat as possible. Do not bend it.
  12. Remove the five screws with the Torx Screwdriver: two near the bottom, two in the middle, and one under the antenna door.
    • Remove the five screws with the Torx Screwdriver: two near the bottom, two in the middle, and one under the antenna door.
    • The two bottom screws are longer than the upper three.
  13. Remove the back covering.
    • Remove the back covering.
  14. Remove the two screws at the top.
    • Remove the two screws at the top.
  15. Remove the metal plating and the circuit board.
    • Remove the metal plating and the circuit board.
    • There is nothing holding the rest of the phone together. Handle the rest of the phone carefully.
    • The LCD will be attached to the circuit board.
  16. Remove the plastic border lying on the keypad.
    • Remove the plastic border lying on the keypad.
  17. Remove the keypad.
    • Remove the keypad.
    • Depending on what you are doing, you can take out or leave the buttons to the keypad in the front casing.
Conclusie
Aaron Jen
1 Reputatie
7 handleidingen geschreven
Cal Poly, Team 27-94, Amido Spring 2010 Lid van Cal Poly, Team 27-94, Amido Spring 2010
CPSU-AMIDO-S10S27G94
4 Leden
14 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 1
Altijd: 15,700
