Ga door naar hoofdinhoud
Nokia 8260 Circuit Board Replacement
Wat je nodig hebt
  1. Nokia 8260 Circuit Board Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off the cell phone.
  2. Nokia 8260 Circuit Board Replacement: stap 2, afbeelding 1 van 1
    • Press down on the round button on the back cover of the phone.
  3. Nokia 8260 Circuit Board Replacement: stap 3, afbeelding 1 van 1
    • Slide the back cover down while still pressing the button.
  4. Nokia 8260 Circuit Board Replacement: stap 4, afbeelding 1 van 1
    • Remove the back cover.
  5. Nokia 8260 Circuit Board Replacement: stap 5, afbeelding 1 van 1
    • Press the end of the battery towards the top of the phone.
  6. Nokia 8260 Circuit Board Replacement: stap 6, afbeelding 1 van 1
    • Lift the battery outwards while still pressing it upwards till it pops out.
    • You may need to take several attempts to lift out the battery.
  7. Nokia 8260 Circuit Board Replacement, Antenna: stap 7, afbeelding 1 van 1
    • Squeeze the flat end of the spudger into the crack right under the word "Nokia" on the back of the phone.
    • This step may be a bit difficult if you are removing the antenna for the first time.
  8. Nokia 8260 Circuit Board Replacement: stap 8, afbeelding 1 van 1
    • Pry open the antenna door by pulling down the top of the spudger
  9. Nokia 8260 Circuit Board Replacement: stap 9, afbeelding 1 van 1
    • Remove the antenna door.
  10. Nokia 8260 Circuit Board Replacement: stap 10, afbeelding 1 van 1
    • If the gold antenna remained stuck to the door, you have finished removing the antenna from the phone.
    • If the gold antenna is still in the phone, carefully remove it and stick it onto the back of the door.
    • Try to keep the antenna as flat as possible. Do not bend it.
  11. Nokia 8260 Circuit Board Replacement, Circuit Board: stap 11, afbeelding 1 van 1
    • Remove the five screws with the Torx Screwdriver: two near the bottom, two in the middle, and one under the antenna door.
    • The two bottom screws are longer than the upper three.
  12. Nokia 8260 Circuit Board Replacement: stap 12, afbeelding 1 van 1
    • Remove the back covering.
  13. Nokia 8260 Circuit Board Replacement: stap 13, afbeelding 1 van 1
    • Remove the two screws at the top.
  14. Nokia 8260 Circuit Board Replacement: stap 14, afbeelding 1 van 1
    • Remove the metal plating and the circuit board.
    • There is nothing holding the rest of the phone together. Handle the rest of the phone carefully.
    • The LCD will be attached to the circuit board.
Conclusie
Aaron Jen
1 Reputatie
7 handleidingen geschreven
Cal Poly, Team 27-94, Amido Spring 2010 Lid van Cal Poly, Team 27-94, Amido Spring 2010
CPSU-AMIDO-S10S27G94
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 2,891
