Ga door naar hoofdinhoud
Nokia 6560 keypad replacement or cleaning
Wat je nodig hebt
  1. Nokia 6560 keypad replacement or cleaning, Battery: stap 1, afbeelding 1 van 2 Nokia 6560 keypad replacement or cleaning, Battery: stap 1, afbeelding 2 van 2
    • Remove the back cover of your cell phone by pushing the small slider with your fingernail towards the top of the phone.
    • Lift off your cell phone's back cover.
  2. Nokia 6560 keypad replacement or cleaning: stap 2, afbeelding 1 van 2 Nokia 6560 keypad replacement or cleaning: stap 2, afbeelding 2 van 2
    • Use your index finger to first push down and then lift up the battery as shown.
    • Remove the battery from your cell phone.
  3. Nokia 6560 keypad replacement or cleaning, Keypad: stap 3, afbeelding 1 van 2 Nokia 6560 keypad replacement or cleaning, Keypad: stap 3, afbeelding 2 van 2
    • Open the front cover of your cell phone with the plastic opening tool or finger nail.
    • Lift the cover upwards, starting from the bottom below the keypad.
  4. Nokia 6560 keypad replacement or cleaning: stap 4, afbeelding 1 van 2 Nokia 6560 keypad replacement or cleaning: stap 4, afbeelding 2 van 2
    • Lift the keypad off of the keyboard as it is not attached to the phone anymore.
    • If you want to clean your keyboard do not use chemical cleaners or too much water, instead, use a damp cloth.
    • It may be tricky to get the keypad in the right position while closing the front cover for the reassembly. Ensure they are aligned properly before closing the front cover!
Conclusie
3 andere personen hebben deze handleiding voltooid.
Tim Bergmann
35 Reputatie
4 handleidingen geschreven
Cal Poly, Team 3-17, Maness Winter 2010 Lid van Cal Poly, Team 3-17, Maness Winter 2010
CPSU-MANESS-W10S3G17
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 5
Altijd: 2,201
