Ga door naar hoofdinhoud
Nokia 6560 Display Replacement
Wat je nodig hebt
  1. Nokia 6560 Display Replacement, Battery: stap 1, afbeelding 1 van 2 Nokia 6560 Display Replacement, Battery: stap 1, afbeelding 2 van 2
    • Remove the back cover of your cell phone by pushing the small slider with your fingernail towards the top of the phone.
    • Lift off your cell phone's back cover.
  2. Nokia 6560 Display Replacement: stap 2, afbeelding 1 van 2 Nokia 6560 Display Replacement: stap 2, afbeelding 2 van 2
    • Use your index finger to first push down and then lift up the battery as shown.
    • Remove the battery from your cell phone.
  3. Nokia 6560 Display Replacement, Keypad: stap 3, afbeelding 1 van 2 Nokia 6560 Display Replacement, Keypad: stap 3, afbeelding 2 van 2
    • Open the front cover of your cell phone with the plastic opening tool or finger nail.
    • Lift the cover upwards, starting from the bottom below the keypad.
  4. Nokia 6560 Display Replacement: stap 4, afbeelding 1 van 2 Nokia 6560 Display Replacement: stap 4, afbeelding 2 van 2
    • Lift the keypad off of the keyboard as it is not attached to the phone anymore.
    • If you want to clean your keyboard do not use chemical cleaners or too much water, instead, use a damp cloth.
    • It may be tricky to get the keypad in the right position while closing the front cover for the reassembly. Ensure they are aligned properly before closing the front cover!
  5. Nokia 6560 Display Replacement, Keyboard: stap 5, afbeelding 1 van 1
    • Unscrew the six T6 torx screws which attach the frame to the cell phone case.
    • Be careful not to scratch your display with the screw driver.
  6. Nokia 6560 Display Replacement: stap 6, afbeelding 1 van 1
    • Lift the frame off of your cell phone.
  7. Nokia 6560 Display Replacement: stap 7, afbeelding 1 van 1
    • Lift the keyboard out of the plastic frame.
  8. Nokia 6560 Display Replacement, Display: stap 8, afbeelding 1 van 2 Nokia 6560 Display Replacement, Display: stap 8, afbeelding 2 van 2
    • Use the plastic opening tool to unmount the thin metal frame at the tab connections. You must do this on both sides.
    • Lift the thin metal frame off of the plastic frame.
    • Pay attention while lifting the frame off because it can easily be bent.
  9. Nokia 6560 Display Replacement: stap 9, afbeelding 1 van 3 Nokia 6560 Display Replacement: stap 9, afbeelding 2 van 3 Nokia 6560 Display Replacement: stap 9, afbeelding 3 van 3
    • Pull the sides of the plastic frame apart in order to loosen the display.
    • Take the display out of the plastic frame.
Conclusie
Nathan Whitacre
21 Reputatie
2 handleidingen geschreven
Cal Poly, Team 3-17, Maness Winter 2010 Lid van Cal Poly, Team 3-17, Maness Winter 2010
CPSU-MANESS-W10S3G17
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 10
Altijd: 1,706
