Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Onderdelen
Geen onderdelen opgegeven.
  1. Press and hold the battery release button and slide the battery away from the Nokia logo Press and hold the battery release button and slide the battery away from the Nokia logo
    • Press and hold the battery release button and slide the battery away from the Nokia logo
  2. Slide the SIM card lock away from the SIM card. The SIM card pops out. Remove the SIM card. The SIM card pops out. Remove the SIM card.
    • Slide the SIM card lock away from the SIM card.
    • The SIM card pops out. Remove the SIM card.
  3. Unscrew and remove the four T6 Torx screws.
    • Unscrew and remove the four T6 Torx screws.
  4. SLA DE UPGRADE OVER
    Bespaar door het te repareren met een alles-in-één kit.
    Koop iPhone-reparatiekits
    SLA DE UPGRADE OVER
  5. Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone. Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone. Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
    • Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
  6. Use the plastic opening tool to separate the top part of the backplate. The plastic clips at the top require slightly more force to separate. The plastic clips at the top require slightly more force to separate.
    • Use the plastic opening tool to separate the top part of the backplate.
    • The plastic clips at the top require slightly more force to separate.
  7. Remove the screw holding the antenna to the circuit board. Carefully lift off the antenna from the circuit board.
    • Remove the screw holding the antenna to the circuit board.
    • Carefully lift off the antenna from the circuit board.
  8. Lift off the motherboard from the faceplate.
    • Lift off the motherboard from the faceplate.
  9. Gently pop out the golden spring in the middle of the speaker. It should come out with little force. Gently pop out the golden spring in the middle of the speaker. It should come out with little force.
    • Gently pop out the golden spring in the middle of the speaker. It should come out with little force.
Conclusie
Mustafa
139 Reputatie
4 handleidingen geschreven
Cal Poly, Team 14-41, Forte Fall 2010 Lid van Cal Poly, Team 14-41, Forte Fall 2010
CPSU-FORTE-F10S14G41
5 Leden
16 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 4,788
