Inleiding
This guide is to instruct the reader about the steps on replacing the internal antenna. The phone will have to be disassembled to reach to the antenna. A proper set of Torx (Star) screw-driver is necessary to complete the procedures.
Wat je nodig hebt
Press and hold the battery release button and slide the battery away from the Nokia logo
Remove the screw holding the antenna to the circuit board.
Carefully lift off the antenna from the circuit board.
3 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Thanks for a nice and helpful instruction.
The rubber power-on button had broken down so I just removed the damaged parts. Now using a toothpick to push the microswitch directly.
Only using the phone indoors for nostalgic reasons, playing Snake :-)
Brgrds Ove
Thanks for antenna help
I have had about three 6310i’s and the on/off button was the failure problem in all three.
