Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the following parts.
Battery cover
Battery
SIM card
Remove two trox screws marked in figure 2.
Remove 5 trox screws that are holding the screen and the touch pad.
After removing the touch pad and the screen.You can remove the logic board from the case.
The board seem don't want to leave its cozy home.
Let's start removing the parts under the logic board.
Parts need to be removed.
A motor
Charger connector
A speaker
Removing the EMI shield.Pry around the edge of the shield to remove it.
Nothing under the EMI shield.
I think we should stop here right now.There are pictures for all parts.
Één opmerking
i have same phone but it's keypad button's are not working.... can u help me that
