Inleiding
Use this guide to remove and repair the logic board.
Wat je nodig hebt
Press and hold the button at the bottom of the back side of the phone while sliding the back plate down to remove the back cover.
Note: Images on the right side may be hovered over to reveal larger versions.
Gereedschap gebruikt in deze stap:T6 Torx Screwdriver$9.99
Using a .208 head T-6 Screwdriver remove the two screws at the bottom of the battery cavity.
