Inleiding
This guide will help locate the microphone for removal and/or repair.
Wat je nodig hebt
Flip over the phone so that the back is facing up.
Pressing your thumb against the back cover, slide the cover off of the phone.
Use the iFixit opening tool to pry out the two tabs at the top corners of the battery compartment.
Pry the keypad out with the plastic opening tool once the motherboard is moved out of the way.
Locate the small speaker module on the back of the separated battery compartment in the lower left hand corner.
Bijna klaar!
Conclusie
