Ga door naar hoofdinhoud
Nokia 6061 Screen Replacement
Wat je nodig hebt
  1. Nokia 6061 Screen Replacement, Screen: stap 1, afbeelding 1 van 3 Nokia 6061 Screen Replacement, Screen: stap 1, afbeelding 2 van 3 Nokia 6061 Screen Replacement, Screen: stap 1, afbeelding 3 van 3
    • Gather the necessary tools:
    • T6 Torx screwdriver
    • Plastic opening tool
    • Small flathead screwdriver
  2. Nokia 6061 Screen Replacement: stap 2, afbeelding 1 van 1
    • This guide will show you how to replace the LCD—after it's been dropped one too many times.
  3. Nokia 6061 Screen Replacement: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Koop
    • Using a 2.0 flathead screwdriver, pry open and remove the black, plastic strip (beneath the screen) to reveal the 2 screws holding the screen in place.
  4. Nokia 6061 Screen Replacement: stap 4, afbeelding 1 van 1
    • Remove the two T6 Torx screws from the base of the display.
  5. Nokia 6061 Screen Replacement: stap 5, afbeelding 1 van 3 Nokia 6061 Screen Replacement: stap 5, afbeelding 2 van 3 Nokia 6061 Screen Replacement: stap 5, afbeelding 3 van 3
    • Once the screws are removed, flip the phone shut.
    • Insert the plastic opening tool at the position indicated and pry along the seam between the front cover and display.
    • Continue prying along the perimeter of the front cover until it is free from the phone.
  6. Nokia 6061 Screen Replacement: stap 6, afbeelding 1 van 2 Nokia 6061 Screen Replacement: stap 6, afbeelding 2 van 2
    • Use a plastic opening tool to pry the LCD circuit board up and out of the phone.
    • Be careful not to damage the circuit board.
    • Flip the display up and over to expose its ribbon cable connector.
  7. Nokia 6061 Screen Replacement: stap 7, afbeelding 1 van 3 Nokia 6061 Screen Replacement: stap 7, afbeelding 2 van 3 Nokia 6061 Screen Replacement: stap 7, afbeelding 3 van 3
    • Use a plastic opening tool to gently pry the LCD ribbon cable connector up out its socket on the LCD circuit board.
    • The other two photos show the male and female sides of the small green connector. Make sure they snap together tightly when the new display is attached.
  8. Nokia 6061 Screen Replacement: stap 8, afbeelding 1 van 1
    • To reassemble your phone, reattach the display to the phone by reconnecting the display ribbon cable. Place the screen assembly back into the front case of the phone.
  9. Nokia 6061 Screen Replacement: stap 9, afbeelding 1 van 1
    • Replace the phone cover by applying pressure until a click is heard.
  10. Nokia 6061 Screen Replacement: stap 10, afbeelding 1 van 1
    • With the cover reattached, flip the phone into the open position and replace the screws removed in step 3. The screw-holes are indicated in the photo.
    • Replace the black, plastic strip by applying pressure until the strip audibly clicks into place.
Eindstreep
rosin7
55 Reputatie
2 handleidingen geschreven
Ohio State, Team 1-3, Buehl Spring 2013 Lid van Ohio State, Team 1-3, Buehl Spring 2013
OSU-BUEHL-S13S1G3
4 Leden
4 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 1,036
