Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
Use this guide to remove and replace the Nokia 6010's keypad.
Onderdelen
Geen onderdelen opgegeven.
  1. Press the small tab on the bottom of the back of the phone. Push the back case upward towards the power button. The back case will then pop off. It requires some force, so be careful.
    • Press the small tab on the bottom of the back of the phone.
    • Push the back case upward towards the power button. The back case will then pop off.
    • It requires some force, so be careful.
  2. Lift the battery near the bottom and pry up. Lift the battery near the bottom and pry up.
    • Lift the battery near the bottom and pry up.
  3. Nintendo Switch-kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. With one hand, press the ridged tab near the visible side of the SIM card.
    • With one hand, press the ridged tab near the visible side of the SIM card.
    • Slide the card out with your other hand.
  5. Grip the phone on either the sides, the top, or the bottom. Pull the front case away from the rest of the phone.
    • Grip the phone on either the sides, the top, or the bottom.
    • Pull the front case away from the rest of the phone.
    • There are no special tabs to keep it in place so it should wiggle free easily.
  6. Lift the keypad away from the body of the phone.
    • Lift the keypad away from the body of the phone.
    • The keypad is the rubber-backed piece with the number keys.
Conclusie
Nicholas Hanne
60 Reputatie
8 handleidingen geschreven
Cal Poly, Team 14-45, Regan Winter 2010 Lid van Cal Poly, Team 14-45, Regan Winter 2010
CPSU-REGAN-W10S14G45
5 Leden
16 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 2,931
