Inleiding
Follow this guide to remove the vibrator from your Nokia 6.
Wat je nodig hebt
Insert the SIM card ejection tool into the hole on the left side of the phone.
Remove the SIM card and microSD card.
Remove 18 screws.
There is one 1 mm x 1.4 mm screw that needs to be removed by a Phillips #000 screwdriver.
One of the screws is 1.2 mm x 4.2 mm and will be removed by a Phillips #00.
The remaining 16 screws can be removed by the Phillips #00 screwdriver and are 1.2 mm x 2.2 mm.
